How to create a Grid Connect automation to turn off lights after a set time?
CSParnell
Hi Team,
I am trying to figure out if there is a work around for the following automation without receiving notification of failure to execute when turning switch off during timer count down.
What I am wanting to set up is a simple:
Light switch On
Light Globe on
Timer 5 Min
Light Globe Off
The issue is if that light switch is turned off during the count down I will get a notification of failure to execute the Light Globe Off command.
Why do I want this?
The kids leave the lights on all the time so I want them to time out and turn off but if we walk by and switch them off then they are off.
If they carry through the automation  and we want to manually switch them back on we just use 2 sec off the switch back on to turn the Globe back on.
I emailed Arlec and they advised no individual muting notification at this time but I thought I'd ask if anyone knows of a work around.
Simple automation  chain below.
Re: How to create a Grid Connect automation to turn off lights after a set time?
Hi again @CSParnell,
Let me tag a few Workshop members who might be able to share their thoughts with you: @MikeTNZ@EricL@cliveg@ericd3nholm@n860cr.
CSParnell
Thank you
Hi @CSParnell
Have you considered putting in an Arlec Grid Connect Smart Motion Sensor? This should make the programming a bit more straight forward just like in this discussion - Grid Connect motion sensor software issues by @ericd3nholm. I then suggest neutralizing the manual switch and leaving it to the motion sensor to keep the light on or off.
Let me call on another Grid enthusiast @macduff89 for their recommendation for this type of set-up.
macduff89
@CSParnell what type of switch is this with? Try using the countdown action under the instead of a timer. I have tried this with a double light switch and it seems to do what you’re after. Switching off before the set time doesn’t produce any notification.
CSParnell
@macduff89
Hey Mate,
When you say double switch are you referring to a 2 way switch? Either way it's breaking the power to the light fitting.
I will try the count down tomorrow and see how that goes and will let you know cheers.
CSParnell
Hi Eric I am considering this for garage lights (for the other lights) but it's not economical for multiple rooms in the house or pleasing to the eye internal.
Carl.
macduff89
@CSParnell I’m talking about one of these: Deta Grid Connect Smart Double Gang Touch Light Switch
Sorry might have misunderstood. I have smart switches for most of my lights so it’s a little bit different. Not sure what actions exist in the app for smart bulbs. If they have the countdown action it should still work.
CSParnell
No there is not a count down option on the bulbs only a set delay so that complicates things.
Hi @CSParnell,
I just had another chat with Arlec to see if there was any way around this issue. They suggested that there will always be a notification of failure to execute in the automation section. Have you tried setting a timer under the globe section? If this timer can't action because of the globe already being turned off, no notification is sent.
I was provided with this information regarding setting a countdown timer, so I would expect that there is a countdown option under the globe section and not just a daily timer of when it turns on and off. However, I suspect the timer option is purely for scheduling a daily routine and not for your intended purpose.
I've provided feedback to our supplier that it would be beneficial to be able to disable this notification, as it inhibits the primary timer function of turning globes off to save power.
