I am thinking of putting a motion-sensitive light (LED) in the roof space to deter possums (nothing else I have tried seems to work). The space is reasonably clean but probably a little dusty (federation house). Would the heat generated by that sort of light be a fire hazard?
Here's another idea for you..As an audio engineer I would put a speaker in a corner of the ceiling and play a CD that has a dog on it barking..and turn up the volume.!!
That might get the little fellow moving.!!
Prof..
Great to have another electrician join the community @tjw1. We look forward to reading a lot more of your posts. Thanks so much for sharing your knowledge and experience with other members.
Martinh
Ill be interested to see how your light works. My daughter works with wires and has dealt with a lot of possums. Unfortunately there is so much competition for nesting / sleeping sites that while it may have a short term effect, but doubtful long term. Typically if you remove one from a territory another will quickly move in. Her advice is if you can figure out where the hole is block it at night when it goes out. JDE
