what do I buy to get this working?
Hi @Kreezy,
Is there an issue with the drill or do you just need accessories?
If the drill is functioning correctly and you just need a bit for various applications, then I'd recommend you take a look at purchasing something similar to the Ryobi 31 Piece Metric Drill & Drive Set RDD31S2. It provides standard driver bits for screws and a good selection of masonry, timber and metal drill bits. Any additional driver bits or drill bits outside this range can be purchased separately when needed. It's a great starting kit. If you want more selection, you could go with the Ryobi 95-Piece Specialty Metric Drill and Drive Set.
In the future, if you have a more specific application in mind, you might wish to invest in more extensive kits for specific uses. These would be driver kits, wood drill bits, metal drill bits, and masonry drill bits.
Here's a helpful article: How to choose the right drill bit for the job.
