Hi, I'm not sure if I'm posting this on the right board, so apologies if this should be elsewhere.
I recently removed an old door and window from a bedroom (which used to be a laundry) and replaced it with a massive window and a brick veneer wall. BUT now that I've almost finished I've realised that I may encounter a problem down the line with moisture. So I'm not sure if I was supposed to put anything between the wood and concrete or between the bricks and concrete.
Have I made a big mistake? If so can this be fixed? Any advice is much appreciated
Abby
Welcome to Workshop @Abby. We're pleased you could join us and hope you get a lot of useful information and inspiration for your projects from fellow Workshop members. Feel free to post anytime you need help or have something to share.
In regards to this question, can I ask where your concern about moisture stems from? I'm sure that there will be community members such as @BIM_Engineer who will be happy to lend assistance.
Thanks,
Have you ever had a plumber check out your drainage under the house @Abby? Might be a good investment.
Yeh, the only reason the water managed to get under the house was through the broken concrete. There were patches where chunks of concrete were missing along the side of the house very close to the wall over time the ground there began to sink and more water accumulated into it. But that's all fixed now. Thanks for the advice
@Abby Thanks for the photos
Also there is no Structure as such to this website (no engineering pun intended)
the experts generally get tagged in.. it's something that takes getting use to I guess?
There should be a Damp Proof Membrane (DPM), weep holes in the brickwork and waterproof flashing fixed around the window & on the timber frame inside the cavity?
It appears the new window opening hasn't been properly flashed this can become a major problem on the weather side, you might want to consider an awning over the window to keep the water from ingressing the window/brick edge..if that helps
Hi and thank you so much for helping out.
There's definitely flashing around the window, and yes I fixed it in properly but it's hiding behind the aluminium frames I added around the window frame as the gap was ugly and you could see the lental at the top. I'll see if I can find a photo to show you what I mean. regarding that smalltimber frame, this is where I'm worried as I forgot to use some damp proofing material. Re weep holes, are they necessary if the brick work is less than 1m wide? Hmmmmm So is there a way I can fix this?
thank you
Abby
We will be improving the structure of the site in the coming weeks as part of our redesign. Watch this space.
@Abby I've put up a generic detail for a brick veneer wall flashings that I use
You may not have all of them listed but let me know so hopefully we can work a solution for you. I highly recommend weep holes beneath windows..tho they can be drilled in later
@JasonI noticed changes to the bunnings site...nice
