Guest toilet room makeover
Lmassih
Building a Reputation
It was time to update our Guest Toilet. Had few inspirations from Pinterest. Decided to try out panelling wall décor.  Measured the toilet room size approx. 1450mm x1200mm wide.
Picked up Pine Primed Dar FJ 31x11mm x 3 lengths and 66x11mm x 1 length from Bunnings.
Materials
Pine primed Dar Fj 31x11mm x 3 Lengths
Dar 66x11mm x 1 Length
Porta 12x12mm 2.4m Quad Tasmanian Oak
SikaBond instant nails fast
Selleys Spackfiller
Sandpaper 240grit
Dulux Concrete Effect
Dulux White Paint
Montgomery floating white shelf 600x38x235mm.
Tools
Measuring tape
Drop-Saw
Clamps
Drill
paint brush
roller
paint tray
Steps
Step 1
We cut to size the pine. We measured at 750 high for the horizontal to sit on top of the tiles. For these we used 31x11mm Pine Dar with spacing of 270mm all around.
The Quad 12x12mm used on the outer corner of the wall to give it a round and smooth edge.
Then we cut the 66x11mm to go all around the top horizontal.
Step 2
We filled, sanded and painted the pine.
We created a feature wall as the bathroom is very small.
We used the Dulux Concrete Effect.
Step 3
Painted the rest of the walls and pine in Dulux White. Added a floating white shelf 600x38x235mm.
Finished with accessories and after 4 days the guest WC was finished.
Re: Guest wash closet makeover
Hello @Lmassih
Thank you very much for sharing your WC makeover. You've done an outstanding effort with the timber moulding and the Dulux paint effects (my favourite). It's totally modernized the look and feel of the room.
Lmassih
Thank you Eric. The Dulux Concrete Effect is my favourite too. We used it as a feature wall in our dinning area where our fireplace is.
Ben2065
Cultivating a Following
Re: Guest toilet room makeover
@Lmassih I would really like to know what the width of the room is where the toilet is positioned? I am looking at making a narrow toilet room and trying to get a sense of what is acceptable. Many thanks
Cheers, Ben
Lmassih
Hi Ben,
Our bathroom is 850mm wide and 1500mm deep.
Attached is our floor plan as a guide.
