Laundry tap only rotating once or twice around the threaded pipe
dchur
Having an Impact
Hey guys,
I must be going for a record for the number of threads about my laundry project here. Appreciate all your replies and effort.
While I wait for the tile adhesive to dry before applying the grout, I wanted to test out the taps and seals.
This picture is of the laundry sink tap pipe. My problem here is when I put on the plumbers tape to seal it I can only rotate about 1.5times around before it gets too tight. Even using no thread tape it only rotates 1.5 times. The added problem here with only rotating that much is even with the dress flange on the tap, there's about 4mm gap between it and the tiles.
Do I need to clean the threads since they seem to be stopping the tap from rotating any further? I'm wary of causing any damage, because that could be costiler.
Thanks.
DIYGnome
Making a Splash
Re: Laundry tap only rotating once or twice around the threaded pipe
Hello @dchur
Surface preparation is always extremely important, I use a wire brush on a drill to clean threads, ensure you use a barrier like plywood (or similar) to reduce the risk of hitting the tiles with the wire wheel... OR be meticulously carefully 👍
Thanks DIYGnome,
I admit I didn't do much, I used a toothpick on the threads but that's it.
Do you reckon a wire brush will better dislodge any gunk causing it to now allow more than 1.5 rotations?
Hello @dchur
Absolutely, when ever I change out a tap washer or similar I always clean the threads back to the bare brass... this way if thereis any damage (or issue) to the thread you can at least see it, speaking of which, under extreme magnification of the photo you supplied there does appear to be irregularities on the leading threads...
Hi @dchur,
Some sound advice there from @DIYGnome. Give the threads a good clean-up and then closely examine them for damage.
Thanks guys.
@DIYGnome yes, I saw that too.
What should I do here? I'm concerned that this is now tiled in, and the pipe is behind masonry wall, I'm hoping this doesn't need to be ripped out but I'd like to get this sorted before I proceed with grouting and silicone for the splashback.
I'm guessing the damage to the threads is likely what's causing it to not go on more than 1.5 rotations.
@dchur,
If you can see that the threads are damaged or cross-threaded, you can sometimes chase them out and restore them by running a hacksaw blade or thin file within the threads. This can open them up enough for the fixture to screw on.
Make sure to put the hacksaw blade in a handle so you don't injure yourself. Also, pop on some gloves and protective eyewear.
Thanks Mitchell.
oh boy, I really don't want to mess this up because this is the threaded copper pipe going into the wall, haha.
I've cleaned the thread as much as I can with what I have and was about to get 3 full rotations of the faucet onto the threading. It's still sticking out from the tiles marginally but I can live with that.
I assume 3 full rotations is enough so long as it's not leaking with the plumbers tape?
@dchur, three full rotations would likely be the minimum. Depending on the style of the spout, you might be able to use one of these cover plates to fill that additional gap.
Thanks @MitchellMc
we're using the Modella range, specifically this for the tap https://www.bunnings.com.au/mondella-black-cadenza-swivel-bath-spout_p0362321
I can't see a black coverplate looking like it matches, however to be honest even a few mm gap with the tiling I can live with if it works.
