Renovating 1970s Bathroom
Ron11
Hello
I am starting to do the reno for a 1970’s bathroom . Trying to see how this can be done in budget .
- Need shower glass and new tap head shower fittings
- Tiles I am unsure if ripping off and re tiling is the only only option ( I saw the tile painting option , but this will be a rental
property so unsure if it would stay ? ) . Also not sure if tiling over the tiles is an option either . Any suggestion would be awesome.
- vanity abs cupboards need to go and replaced
- this does not have a toilet . Unsure how much would the plumbing cost if to get a toilet also included . Still thinking
Would be great to hear some budget friendly ideas .
Also this is a fibro redone with brick . So
ripping off the tiles may require the asbestos
specialists to come
in as well . So trying to work around that .
Thank you very much
regards
Re: Renovating 1970s Bathroom
Hi @Ron11,
Welcome to the Bunnings Workshop community. We're so pleased you could join us and are so looking forward to seeing how you can transform this bathroom. Apologies for the delay in getting back to you.
You might like to start by checking out the excellent advice from the Bunnings team about How to plan a bathroom renovation. I will also add the video below.
Our Top 10 most popular bathroom projects should also be helpful in providing ideas and inspiration.
I'm sure our resident Bunnings D.I.Y. expert @EricL will be happy to assist with your questions. Let me also tag @Mathy and @JDE to see if they might be able to share their thoughts.
I would also encourage you to share a simple plan of the space with dimensions so members have a better idea of what you are working with.
Many thanks,
Hello @Ron11
It's great that my colleague @Jason has pointed you to those useful guides to give you ideas. Would it be possible for you to post the dimensions of your bathroom? This will give me a better idea of the space you have and make my recommended sketches accurate. I will post both ideas for you, with and without the toilet to give you a better idea of what it might look like. Please make sure to indicate where the location of the door is.
We look forward to seeing those measurements.
Ron11
Thank you for that Eric , does this help ?
Hello @Ron11
Thank you for posting that information. If you are after a quick turnaround and refresh, I suggest regrouting the tiles and repainting the room. Removing and replacing the vanity and mirror cabinet with new ones should make for a quick refresh. Your other option is to tile over the existing tiles to avoid having to spend money on removing the asbestos. If you put a toilet in the current shower room, you will have to engage the services of an asbestos removal specialist.
However, if time permits and a proper renovation is within your budget, I recommend re-tiling the bathroom and putting a toilet in. Due to space limitations, I can only put in a glass panel and not a full shower enclosure. If you decide to not place the toilet in, I suggest removing the glass panel to give you maximum use of the shower space. A shower curtain is an option if you wish to limit the amount of water splashing into the rest of the room.
Let me tag our experienced members @prettyliving and @tom_builds for their recommendations on the layout of your bathroom.
Have a look at my sketches and tell me what you think.
If you need more information and advice, please let us know.
tom_builds
Making a Splash
Hi @Ron11 ,
Sound like you have an exciting project planned. Updating a bathroom can make a huge difference to the amenity of a house.
I agree with the thoughts of @EricL that @tiling over your current tiles and redoing the vanity is probably your best bet for a quick and painless update.
Unfortunately any more than that and I think you will need the asbestos professional to remove the sheeting, as even adjusting the current shower tape will probably involve disturbing the cladding. As @EricL mentioned the addition of any new fixtures, like a toilet, will also involve handling asbestos.
Ideally having the asbestos removed and recladding the room will give you the best finish and will mean that in the future you will be able to make small changes without concern, but obviously asbestos removal isn't cheap so may be outside of your budget.
Let us know which path you decide to go down and keep us updated with your progress.
Best of luck
Mishmash
Building a Reputation
I’m keen to watch it unfold as I will be doing this soon.
Just waiting for our property to finalise.
Our whole property needs renovating that we are buying ,but we are going to take our time as we live in another.
I’m feeling your pain as you never need to overspend but also spend wisely.
Spraying over the tiles could be an option and it works, key is in the prep I feel and quality paint.
We have done this previously in another home we flipped.
Hope it helps and good luck.
Mishmash
They look amazing.☺️
Feel free to hit the Start a discussion button anytime @Mishmash. We'd love to see your plans and help you along the way.
Ron11
Thanks to all your comments . I am making slow progress with the lockdown . The walls are stripped on on two sides and new cement sheets are put up . Now trying to get the walls tiled . I was told by a toilet that I will have to remove the floor tiles also as you cannot just waterproof the walls .  Is that a problem ? Could you please let me know ?
thanks
