I need 2-way taps for two washing machines. Could you please advise which tap or outlet is good?
Hello @JunoK
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about washing machine taps.
If you wisht to install standard washing machine taps I suggest looking at Estilo Chrome Washing Machine Set one for hot and one for cold outlets. If you wish to have two outlets on one tap, I suggest installing a Pope 2 Way Brass Threaded Tap on the end of the washing machine taps. My best advice is to tell your plumber that you plan on installing a two way tap at end of the washing machine tap and that an extension must be installed so that you can rotate the Pope two-way tap.
If you had another configuration in mind, please let us know.
