We have recently finished a bathroom renovation and we are now moving on to landscaping the back yard. As part of the bathroom reno, there was a new Overflow Relief Gully (i think thats right?) installed which sits right in the spot we were looking at installing a bench seat, so i have a couple of questions on if it is possible for the position of the above ground outlet to be moved. See attached picture.
The green line is floor level, and i understand the outlet needs to be 150mm below this - no problems there.
Are there any specific rules around if i can have bends in the above ground portion of the pipe? I see 2 possible solutions to our issue.
1. Red line - simply put a 90 degree bend and move it out of the way, with the end of the pipe outlet being horizontal.
2. Blue Line - put a "dog leg" in it and move the outlet to a more convenient position to let the bench seat be constructed.
Are either of these 2 options "allowed"? I couldnt see any regulations that stated there must be direct (ie: vertical) access to the pipe incase of blockage or whatever. Anything else that i am missing that may cause either of these options to not be viable?
We have attempted to reach out to the plumber that did the initial work to ask this question, but it was a good 3+ years ago and he seems to be uncontactable. Once we know what is or isnt allowed we can make the design changes to suit, then get a plumber in to do the work.
Thanks in advance.
