Hi. I have been cleaning the grout on the bath tiles by splashing Domestos but this has stained the bath. I am using hydrogen peroxide for the white streaky stains, but it isn’t working on the dark stain (see photo). I was wondering if anyone knows how to repair or minimise the dark stain on this pink bath?
Hello @CatherineXX
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your bath.
I propose testing a small section of the stain with CLR 750ml Ready To Use Calcium Lime Rust Remover in combination with Scrub Daddy Eraser Daddy - 2 Pack (please make sure to soak in water before use, do not use it when it is dry) If it starts to remove the stain you can then commit the entire area. Please make sure to rinse the entire area with water before using the bath again.
Thank you Eric. I’m a bit worried that might damage the bath further. I think the dark stain is black scratches where somebody was trying to scrape the white streaks off. My friend is coming to look at it this week. If anyone else has any ideas, thanks in advance 🙂
Hello @CatherineXX
If you are after something more natural, I suggest using Glitz 2L Cleaning Vinegar in combination with the Scrub Daddy Eraser Daddy - 2 Pack. Mix 50/50 with water in a spray bottle and use it on the stain. Let it sit for at least 10 minutes and wash off with water and detergent.
Thank you Eric
