What replacement buffing polishing pads for Ozito PXBSPS-180 sander and polisher?
acicco
Growing in Experience
Hi
We purchased this Ozito 2 in 1 sander and polisher: https://www.bunnings.com.au/ozito-pxc-18v-brushless-2-in-1-sander-and-polisher-pxbsps-180-skin-only_...
I am however unable to locate any suitable replacement buffing pads for this specific model unless I’m missing something obvious? The manual states the disc diameter is 180mm if I have read correctly. Is anyone able to please advise on suitable pads?
thanks
Re: Ozito replacement buffing polishing pads
Hello @acicco
Thanks for sharing your question about the Ozito PXC 18V Brushless 2 In 1 Sander And Polisher PXBSPS-180. Have you had a chance to speak to the tool specialist at your store? They might be aware if there is a head kitset available for your polisher. If not, odds are the buffing/sanding set will need to be specially ordered from the special orders desk. I suspect that it can't be purchased on an individual basis and must be ordered as a kit set.
Please allow us to contact our supplier in regards to the buffing/sanding set. As soon as we have more information, we'll get back to you.
Thank you for your patience.
acicco
Thanks for the quick reply Eric
Unfortunately I haven’t been able to get into a store to speak to someone as we are currently a few hours away from the nearest store so I was searching online without any success.
I’m happy to call them tomorrow given it may be a special orders purchase but I will also await your reply from the suppliers.
thanks again
Hello @acicco
I've just been in contact with Ozito's customer service team and the part you are after needs to be specially ordered. I've placed a diagram below and the part number you are after is the 139/135/136/137. These represent the buffing pads and the sandpaper set. Please proceed to your stores special orders desk and show them this diagram and point to the parts that you are after. They will then contact Ozito and make a quote for you.
Nailbag
Home Improvement Guru
Re: What replacement buffing polishing pads for Ozito PXBSPS-180 sander and polisher?
Hi @acicco
Any brand of 180mm polishing bonnet with a drawstring will fit that rubber platen. Just Google "180mm polishing bonnet" The auto shops have them like this one or this one and there are lots available you can order online.
Nailbag
