Do I need drainage under the raised beds?
vineet
Hi
I am laying pavers and at the lower slope end is the raised beds. I am sloping pavers at about 50mm for ~3m width but I am concerned that the end of the slope is raised beds so how will water drain. After laying pavers it will come to around the height of the first level sleepers.
question- do I need put drainage before the sleepers.
Re: do I need drainage under the raised beds
Hi @vineet
Maybe start with exploring the terms used for permeable pavers. When I did my research I intended to replace pavers on a side walk that can get very damp and slippery in winter. I have however found that I can reuse the concrete pavers from our old patio, so I haven't pursued this option further.
There are some impressive videos on YouTube showing how some of these pavers let gushing water pass through.
Depending on your particular situation I'd make sure that if you use this option there is sufficient depth to the roadbase underneath the pavers.
And yes, I wouldn't use any sealing materials to enable the water to drain. The surrounding elements (sleepers, other pavers) will give your draining course enough edge support to not wander off.
Hi @vineet
That's an excellent recommendation coming from @TheHandySqirrel. Please keep in mind that soil testing might be required to see how permeable your soil is. It's also a good opportunity to ask how high the permeable system will be when placed against your house and raised garden.
vineet
Thank you for the advice. For now I have decided to put the drainage but the permeable pavers gave me a great idea for a side pathway. Going to do the job now:)
vineet
Hi all, I finished the job in January and thought I will come back and thank you everyone. The end results is probably not a professional class but good enough to get appreciation for wify...
It looks like you've achieved a wonderful finish there, @vineet, far better than some professional work I've seen. You should be very proud of your efforts!
I'll be looking forward to seeing what project you tackle next.
Many thanks for sharing your results.
