Tuscan Path 15kg 30-50mm White Pebbles. How many bags will I need for a 4 metre diameter circle?
Hi @gardenspecial,
I'd suggest using the Tuscan Path Pebbles Calculator for this calculation.
You can select the option to calculate by area. For a circle with a 4m diameter, the area is approximately 12.57 m².
If you plug this into the calculator, at a depth of 60mm, which is fairly common, it says you would need 88 bags.
