Top Cat colourful planter
Jamespeter100
Making a Splash
Top Cat and the gang as planters. If outside, leave the bottom open so the water doesn’t go on the wood. If inside, a saucer to catch the water, lift the plants out to water and drain.
Materials
MDF, screws 8g 40mm, paints and thin brushes.
Tools
Steps
Step 1
Draw the faces in on paper, it’s easier than drawing on the mdf. Cut out the faces, with a lead pencil, draw all over the back. Now place the paper face up onto the mdf wood, draw over the previous lines, a faint image will appear in the wood. Cut them out. Mark
out the sides on the mdf, To save wood I intermingle two tails at a time.
Step 2
Fine lines, either a long screw, dipped in paint, where the paint goes down screw.  Or a texta, but the texta will fade.
Noyade
Home Improvement Guru
Re: Top Cat colourful planter
Hi @Jason
"I'm definitely a lot older than @JacobZ."
Do you also remember Q.T. Hush?
https://en.wikipedia.org/wiki/Q._T._Hush
Haven't seen that one before @Noyade
I loved the classic Looney Tunes like Bugs Bunny cartoons the most.
