What to do in the garden in August
Your garden is mostly dormant in winter and the cold, wet weather makes it hard to get outside. But August marks the transition period between the cold and warm months, making it a great time to get out there and get your garden ready for spring.
What to pick
Once August comes around, your winter crops will have reached the end of their growth cycle. If you’ve planted any winter veggies or herbs, then it’s your last chance to reap the benefits.
Harvest any remaining artichoke, asparagus, beetroot, broad beans, broccoli, Brussels sprout, cabbage, carrot, cauliflower, celery, leek, lettuce, silverbeet, spinach, radish, peas and snow peas.
Gather up your herbs, including chives, curry, dill, mint, parsley, sage and thyme. Then dry them out so that they’ll last longer.
For warmer areas, your eggplant, okra, pigeon peas, snake beans, sweet potato, rosella, and watermelons should all be ready to enjoy.
What to plant
When it comes to growing, timing is everything. You can still plant winter veggies like peas, broad beans, onions, spring onions, chives, and leeks. It’s getting a bit late for cabbages, cauliflower and broccoli now but you could still plant in some good-sized seedlings at the start of the month.
Early varieties of spring vegetables like carrots, silverbeet, and spinach can tolerate the cold. However, you’re better off with seedlings because seeds will take a while to come up.
If you’re really keen, you can grow spring and summer vegetable seedlings indoors. Plant pumpkins, beans, tomatoes, corn, zucchini or watermelons in seed trays and place them in a well-lit area. Nurse them through until the weather warms up and transfer to your garden in spring.
But if you live in a warmer region, you can start on spring vegetables a bit earlier. Think about snow peas, rocket, silverbeet, spring onions, cabbage, lettuce, parsley, zucchini, pumpkin, leek and parsnip.
And as it gets warmer, sow tomatoes, capsicum, eggplant, beans, cucumber, pumpkin, beetroot, silverbeet, cabbage, carrots, lettuce, radish, and even early season potatoes.
What to do
If you want your garden to thrive in spring, then you need to do your groundwork now. With a bit of planning you can ensure its success all the way through to summer.
Build up your soil
The biggest thing you can do for your garden in August is feed the soil. Start digging in any compost and manures, and adding fertilisers, so that they’re breaking down by the time you’re ready to plant.
This will improve your soil’s ability to use moisture, encourage worm activity, and promote microbes that help release the nutrients in your soil. It also increases fibrous root growth to suck up all that nutrition.
Weed regularly
After the rains subside, the last thing your plants need is competition for water and nutrients. It’s important to weed regularly so that they don’t take a hold. Once you’ve removed them, throw down a layer of mulch. It’ll deprive the weeds of the light they need to germinate and stop any airborne seeds from landing on your soil and taking root.
Mulch
Mulching is always a great idea because it improves soil structure and helps retain moisture for the warmer months ahead. Remember, if you plant seeds you can’t mulch until they’ve established themselves.
Pea straw mulch is ideal because it adds more nutrients to your soil than most other mulches. Lay down a 10cm thick layer over the soil around your plants, which will last about 12 months. You can even put down a layer of newspaper first to reduce evaporation and lock in the moisture.
Prune your plants and trees
Pruning plants gets them back into shape and encourages new growth. The end of winter is the time to do it because most of them are dormant or at the end of their flowering cycle.
Roses and fruit trees need a hard prune. Remove any dead, diseased or crossing branches. Cut off old flower heads on young plants and cut back the branches on mature plants by up to a third. Make sure you cut cleanly so that it’s easier for the plant to heal.
After pruning, it’s a good idea to give plants a spray with lime sulphur, which stops exposed cuts from getting fungal infections. Also spray on the ground, at the base of the plant, to get rid of any fungal spores that could infect your plant later.
Feel free to let us know what you're up to in the garden at the moment by replying below or hitting the Start a discussion button.
Re: What to do in the garden in August
Hi @BradN,
@Eric will be back after the weekend, and I trust he'll add to my response if I've missed anything.
The best time to tackle Bindi is as soon as you see the leaves appear and well before the prickles develop. Typically this is late winter or early spring. If the Bindii has been giving you particular trouble, then I would advise applying a product like BuffaloPro Selective Bindii and Broadleaf Weed Killer now if you've already seen them popping up and spreading the Weed'n'Feed in early spring. The Weed'n'Feed will take care of any remaining Bindii and feed in the warmer months. Do not use the standard spray-on Weed'n'Feed on Buffalo, as it will kill it. If you want a spray-on product, you must use the Buffalo-specific Weed'n'Feed.
Have you considered coring the soil? We have a manual version, but if you are dreading the process, you could consider hiring a small mechanical version for the job. The beauty of coring (though it makes a bit of a mess) is that it allows you to really get the sand down into the soil. You should only need to do it once every five years or more. We have the Saxon Lawn Aerator Spiked Roller, but if I were to use it I'd likely work out how to strap some weight onto it.
BradN
Retired Team Member
Retired Team Member
Hi @MitchellMc  Thanks for that. I think that coring tool is just what I need. I need to get some proper plugs out of the lawn rather than just making little holes that will close back up straight away. The lawn isn't so big that I'll need to hire a machine – it's just big enough to make it a bit of a pain to do.
Thanks for the advice on the Bindii in the buffalo too. I might pick up a bottle of that concentrate today.
Cheers,
Brad
Akanksha
Projects Editor
Projects Editor
August is here again. We're officially one month away from spring!
How are everyone's gardens looking at the moment?
Akanksha
Dave-1
Home Improvement Guru
Good Morning @Akanksha
The garden is looking "Winterised" lol Grass is brown, weeds are deadish and it look scraggly... I can feel the pressure to switch from reno work to garden work to prep for spring!  My tomato beds need to be turned and prepped (Just havested my last cherry tomatoes a week ago) Looks like I know what this weekend will be bringing :smile:
gen1
hi Jason,
At work we have a raised garden bed which we are trying to cultivate the soil so we can plant vegetables. I am a nurse in mental health rehabilitation unit and one of our activity that we want our consumer/residents to do is gardening. No one have a clue on what to do. I was so thankful that I found a community that shares ideas and information what to do in gardening. I will send a picture in my next post when I am back at work. Someone in the community hopefully can help us with our gardening group because we don't have any idea on what to do. We tried planting but no success. I have no clue what we need. We need someone who can advise us and direct us to the right direction. We have bunnings gift vouchers given to us by the family of our residents but we don't know where to start. We need advice from people who knows what we need to do before we start using our bunnings gift cards.
So I can access the community group at work.
gen1
Hello @gen1
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thank you for sharing with us your plans for creating a garden.
Once you've posted a photo of the proposed garden area, this will give our members a chance to assess its location. We can then make recommendations on soil preparation and the type of plants you can put in. Can you also please tell us if the area gets a lot of sun, and does it flood when there is a large deluge of rain?
Since you're planning a new project, I suggest creating a new discussion by clicking on the "Ask a question" button.
We look forward to seeing pictures of your garden area.
Looking forward to being able to assist @gen1
As per Eric's message, please hit the Ask a question button and share as much detail as you can about the growing conditions. It sounds like a great spring project and we're sure you can have a flourishing garden when the warmer weather arrives.
