Hi. I’m installing a Kaboodle kitchen and I am ready to install the overhead cupboard which is 800mm wide by 300mm deep. My question is, what wall anchors (type and size) should I use to ensure it is secure? The wall is single cavity brick. Your help is greatly appreciated.
Welcome to the Bunnings Workshop community @Laura79. It's brilliant to have you join us, and many thanks for your question about hanging cabinets.
These Ramset 6 x 75mm Countersunk DynaBolt Plus Masonry Anchors would be suitable for mounting cabinets to a single brick wall. You'll need to pre-drill 8mm holes in the masonry wall.
Many thanks Mitchell! I’m thinking one in each corner would be sufficient?
One in each corner is what Kaboodle recommends for standard use, @Laura79. If you're going to be really loading up the cabinet with heavy items, you can also pop an additional one in the middle at the top and bottom.
