I'm planning a kitchen renovation where there are two pillars/posts in the middle of the area, which limit the use of space. The pillars support the ceiling and the flat roof above, which is clad with galvanised iron. The ideal situation would be to remove the pillars and support the roof with a single beam, fitted as much as possible into the limited ceiling space to mimimize how far it protrudes under the ceiling. The existing pillars already support timberwork protruding around 100mm below the ceiling level. There is around 150mm between the ceiling and the bottom of the iron roof.
For the beam to be fitted into the ceiling space the existing rafters would have to be attached to it with hanger brackets. If that is acceptable then if a beam of around 200mm depth would not protrude below the ceiling any more than the existing setup.
I estimate the weight of the roofing, roof timberwork and gyprock ceiling to be around 350Kg, evenly distributed across the width. (The only other loading might be someone working on the roof if necessary).
Before engaging an engineer to properly appraise the situation, I'm seeking some general advice to see whether the above solution is feasible. If the beam required would need to be greater than say 250mm in depth, then I think that would protrude too far beneath the existing ceiling to be workable. If it would need to be installed as an underpurlin then definitely unacceptable.
I have attached a photo showing the existing posts.
Any advice or suggestions would be most appreciated. Thanks in advance.
Bill
