Hi guys, I'd like to stain my new dining chair legs to match our wooden floorboards, but I'm a complete novice at DIY. Can anyone please kindly suggest what colour stain I should consider? Thank you in advance!
Hi @jjj_z
Firstly we can help try match your floor stain color. AS this is your goal and personal preferance.
But some times having contrasting or different textures /looks adds to your space.
I say this as it is hard for a perfect match re staining.
Where your floors stained or are they pre made? The name of your timber color and or stain maybe a guide to close match.
In the meanwhile to closest color match to your floor color is (Kowhia by Forestwood timber stain by wattyl ) Depending on how it takes to your chair legs. Color chart https://wattyl.com.au/wp-content/uploads/2022/12/Wattyl-Forestwood-Brochure-AU-Web.pdf
Apply stain using a bit of old rag folded into a small square dab to rag to the stain tin to pick up color then lightly wpie over the chair legs or pre test the stain colour on clear pine for a close sample,.
Each time you wipe the chair leg the color will darken on the leg so it is easy to over do the staining. Take care.
Once you know your stain works on your chairs note down color for future reference as you may want to match other timber to your theme.
Wow. Thank you so much for such a detailed response - this is actually so helpful!! And having a look at the Kowhai stain, it looks so similar to the floor!
I'm not too sure about whether our hardwood floors were stained or premade as it was installed by the builder of our apartment building - and I've looked through the paint manual and there's no mention...
I'll be giving this a go. Thank you so much again!!
Hello @jjj_z
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thanks for sharing your question about what stain to use on your chair legs.
It's great that you've received excellent advice from @Jewelleryrescue. I totally agree with the suggestions made. I would also recommend making sure to test it on some clean pine and to provide enough time for the stain to dry off and settle. You'll get a much better idea of the colour when it is dry.
Please make sure to wear personal protection such as gloves, goggles, and a mask when working on your project.
