How to lay hybrid flooring in wardrobe?
Sugar
Making a Splash
Hi guys,
I am going to lay Hybrid flooring on my wardrobe. 1400 x 2350 size. Not big. This is a part of walk in wardrobe makeover.
I have few question.
  • Currently the walk in robe area has carpert that is part of main bed room. I will still have new carpet in my bed room but how do I go about having transition of carpet to timber ?
  • What do I need to make the transition or join look professional ?
  • What options do I have ?
https://www.bunnings.com.au/products/flooring-tiles/timber-floors/hybrid-flooring
  • What devices do I need to cut to size, if I required to ?
  • What are the process to do it.
I am sure somone must have already done it. I thoght I should start a fresh conversation.
Re: How to lay hybrid flooring in wardrobe?
Hi @JacobZ
Thanks mate, for you reply.
Following is the instruction to install the wardrobe I have bought. This is screenshot.
It says "removing the skirting board to sit flush against the wall".
Is it possible to lay timber/hybrid flooring without the skirting board? This is twist here.
If the skirting board has to be there for flooring then I can only see (as an option) to have the Longer Wall Plugs to secure wardrobes, so that the wardrobe does not has to tilt backwards towards the wall.
Any recommendations are welcome. Thanks.
Hello @Sugar
If you remove the skirting board the wardrobe will go over the gap and hide it. The remaining skirting board will simply need to be cut so that it ends up at the wall panel of the wardrobe. But if you wish for the skirting board to remain you can use a timber filler to go behind the wardrobe so that it does not tilt when you install the screw and wall plugs. The timber filler does not have to be big for example, 42x19mm might work, it all depends on how large the gap is. The timber piece can be screwed onto the back of the wardrobe.
