How to repair a front door frame?
Innov8tive
Building a Reputation
I need to attach this piece to the door frame of the front door. I will be removing the old nails. What is the best way to securely attach this piece to the door frame? Tools I have. A hammer, reverse ozito drill and my own muscle power. Would rather not buy any new tools. On a budget so just the best way to attach this piece would be great.
Re: Repairing a front door frame
Hi @Innov8tive,
Those trim pieces are usually just nailed into place, so it’s a fairly straightforward repair. Once you’ve straightened the nails out and knocked them out of the holes, I’d suggest re-using those same holes and driving new nails through into the wall frame. That way, you’re not making extra holes in the timber. To give it a bit more strength and stop it from working loose again, you can also run a small bead of Liquid Nails behind the trim before fixing it back in position. That combination of adhesive and nails should hold it securely without needing any extra tools.
hi @MitchellMc
Will those nails be a bit thick for this particular timber piece? The original nails are quite thin. Does the liquid nails come with an applicator or will I need to purchase an applicator?
You can certainly drop down to Paslode 50 x 2.0mm 100g Bright Steel Bullet Head Nails, @Innov8tive. Ideally, you want to use something similar to what was used previously.
There's Selleys 130g Liquid Nails Fast Grab Strong Adhesive, which is a squeeze tube and doesn't require an applicator. Or the caulking cartridges require a caulking gun.
@MitchellMc
Thanks for the advice. I think I might go with the nails suggested in your second response. I will grab Selleys Liquid Nails 100 gram as I really only need it for this piece of timber.
