Hi Team,
I have a little challenge with a water leaking aluminum sliding door frame.
Current Status:
I have removed damaged render/concrete in around and below the aluminum frame. I have installed bituminous flashing under the base of the frame and the affected side. You should be able to see this in the images.
The inside has a channel/gap between the aluminum door frame and the floor slab that needs to be closed/sealed.
The outside has damaged render or brickwork beneath the threshold that you want to rebuild and weatherproof.
Goal:
Seal and close the internal channel next to the frame.
Overlay flashing correctly (tie into the wall or slab as needed).
Rebuild/render the damaged area externally, integrating the flashing to maintain water-tightness.
It would be great to get recommendations to what materials to use and what to do first...
thanks a lot,
Lars
