Need inspiration for dry bar area
Jersey1975
Building a Reputation
Hi there I have built this but stuck on what to put above.  OPtions are
Arch with shelves
Cupboard with glass doors on one side then shelves
BUT we really want a wine rack in there but no idea how to include it or build it, would love any inspo please.
Re: Dry bar inspiration!
Afternoon @Jersey1975
Then they would cut it no probs. Please note that the cuts are not neccasarily on the mm mark. That is up to us to get right otherwise they could potentially have all of us come back and say "it is wrong" and "I want another piece" :smile: So my best rule of thumb would be to get it cut to a few cms over the length you need and when you get it home do the final cut that is accurate.
Hi @Jersey1975,
@Dave-1 is correct that if it is purchased on the day, our warehouses are set up to cut timber panels to the nearest 100mm for ease of transport. Unfortunately, we cannot make precision cuts to the nearest millimetre.
I would be happy to assist you with cutting the shelf yourself to make it as snug as possible.
You might like to read the advice I gave in the discussion - Would you buy a Mitre Saw or Circular Saw First? - where I have shared some tips to make the best cut possible.
Let me know what you think.
Jersey1975
Oh yes please Jacob my cutting is useless! I would love to learn how to get it right first time I have a circular saw and have borrowed a cheap mitre saw thank you!
Hi @Jersey1975,
The first thing I'd suggest is to be really sure of your measurements beforehand. You can never trust that walls are square, so you should always measure with the assumption that they aren't.
Use a spirit level to mark a perfectly level pencil line on all three walls of the opening. You can then measure all three sides of the opening along this level line and then measure the distance between the pencil marks at where the front of the shelf will sit.
When measuring sheet products before cutting, I'd always draw the shape on a scrap of paper and mark the measurements on each side so I have a reference I can use to transfer the marks onto the material I am cutting. That way, I don't get confused about what measurement relates to which side.
When you are marking your shelf for cutting, use a sharp pencil and a straight edge to make sure the line is perfectly where you want it and remember which side of the line is being removed. This is because you will always want to cut up to the line, not through the line. Your blade is 2-3mm wide, so if your mark is perfectly on the point that you've measured, if your saw blade runs directly through the centre of the line you will be half a blade's width off which is between 1-1.5mm.
Set your blade depth so it will only just pass through the material. This is the best way to ensure you are not overloading the saw which can cause it to go offline.
You can then use some clamps with your spirit level to set a guide to cut along. Check out what they've done in How To Cut Laminate Benchtop for an example of this in action.
Finally, remember to take it slow, there's no reason to rush.
Let me know if you have any further questions and if you'd like some more assistance, please don't hesitate to reach out.
Jersey1975
Thanks so much
Jersey1975
 finished thank you to everyone who helped me achieve this! Really pleased
Great job @Jersey1975!
It's come up wonderfully and I'm so glad I could help.
Thank you for sharing the finished project.
Evening @Jersey1975
Now thats a solid effort! :smile: It looks great!
Stylish and looks like what you described from the beginning! :laugh:
Any things you would change/note if someone else was thinking of a similar project? And Is there any chance of you putting a project together to show your steps? :smile:
Jersey1975
Thanks so much!
id love to put the steps together shall I do it as a post? So grateful for all the help on here and improved my cutting skills now!
Hi @Jersey1975
I definitely encourage you to line up all the steps you took along with the pictures that you've taken and to turn it into a project post. Simply click on the share a project button at the top of the webpage to get going.
