help required
joannelee
help required
I have a hole in th wall a built-in wardrobe was not  finished left with a big hole an no clue what to do next or the  first case may bea my pergola leaks every spot you stand an the mobility scooter gets wet .
Re: help required
Welcome to the Bunnings Workshop community @joannelee. It's great to have you join us and many thanks for your question.
Some photos of the affected areas and additional information would really help our fantastic members in offering some great advice. Was the hole from the unfinished wardrobe in a plaster wall or perhaps a brick wall? Is your pergola leaking through damage to the roofing sheets or maybe the fixing screws?
If the hole is in a wall which is plasterboard then here's a helpful step-by-step D.I.Y. article on How to fix a hole in a plaster wall.
We look forward to hearing further details on your projects and assisting you with fixing the issues.
