What paint to use on MDF?
ventodimare
Building a Reputation
Hello,
I have a square of mfd. I want to paint it in white. The paint  must withstand some cleaning (wet cloth with standard kitchen products). Is there a paint that I could use?
Thanks a mil
Re: mdf square
Hi @ventodimare,
Start with a good primer, since raw MDF is very absorbent and can swell if exposed directly to moisture. I'd suggest this Dulux 1Step Prep Primer, Sealer & Undercoat is a great option.
Once primed and dry, you can use a water-based enamel paint like Dulux Aquanamel in a satin or semi-gloss finish. It dries hard, is moisture-resistant, and is specifically formulated to withstand regular cleaning.
Use a high density foam roller to apply the primer and paint. One of these rollers will give you a very even, streak-free finish without leaving roller texture or lint behind. MDF has a flat, smooth surface, and a foam roller helps maintain that look by laying down a thin, uniform coat of paint that levels out nicely as it dries.
Ensure you let each coat cure fully before using any kitchen cleaners on it.
