Bird bath autofill & recycle with timer & float level - Part 2
AlanM52
Part 1 of this project can be found here - https://www.workshop.bunnings.com.au/t5/Outdoor/Bird-bath-auto-fill-amp-recycle-with-timer-amp-float...
In this session we make the:
Water level float indicator.
Install the float switch.
Sponge filter for pump.
Connect bird bath to timer in workshop.
Materials
Large pot plant saucer.
Air Wick Essential Oils Freshmatic Vanilla & Soft Cashmere Air Freshener Refill (Empty Can)
Thin metal rod from decorative garden stake.
Aluminium tube from wind chime.
Electric fencing wire.
Tools
General DIY tools.
Steps
Step 1
Water level indicator.
You only need the wire rod.
Empty can. I now save them so i can periodically replace as needed.
Drill a hole half way between centre and rim.
The aluminum float tube with modified furniture knob plus wooden block for additional support.
Looks like this.
Step 2
Run Dry Float switch
The float switch is mounted at at one end of 42 x 19mm pine timber and the top end secured to the rim of the bucket with a small bracket.
Step 3
Water pump.
The pump simply sits at the bottom of the bucket.
I made a small push-on filter from a larger (used) AQUAPRO Small Pre-Filter Sponge (2813407).
I used a mini coke can to protect the motor wire connections (wire nuts) and from here electric fencing wire (in conduit) back the garage aka workshop where it connects to the digital timer relay N/O contacts.
Wire nut kit.
Step 4
Digital timer and wiring diagram.
Timer Switch, CN101A, DC-AC 24V 16Amp, Digital LCD Power Programmable Timer Time Relay Switch, Supports 28 Scheduled Times Daily or Weekly .jpg
This is the digital timer I used, if you purchase this or a similar one make sure it is DC 12V.
https://tinyurl.com/yc5z9s23
The pump and the float switch wire connections are protected with a upside down mini coke can (or similar).
I used electric fence wire to connect from here to the timer in the workshop nearby which is powered by a 12V power adaptor.
Convert to solar... the timer could also be installed in a waterproof box along with a 12V AGM battery and solar controller plus solar panel.
Step 5
The float level switch is wired in series with the pump (+) wire.
The pump (-) wire straight through to the timer.
Re: Bird bath autofill & recycle with timer & float level - Part 2
Hello @AlanM52
Thanks for sharing the extra details of your birdbath auto fill mechanism.
