I'm planning on building a deck over the back patio using Ekodeck Plus from Bunnings. I'm planning on using Klevaklip Adjustable Joist Supports (https://www.klevaklip.com.au/Joist-Supports) to keep the joists off the concrete (if it rains in the right direction, the patio gets wet). I'm was thinking of using 90x45mm h3 treated pine for the joists - and this is where my confusion starts to set in. Is that appropriate to use for this type of deck? And then I'm unsure of how far apart the joist supports should be placed. The joists will be spaced a maximum of 450mm apart, but the supports holding them I'm unsure of. The Klevaklip website has the span distance with recommended and maximum distances, just unsure if that would take into account the heavier composite decking.
I've added some photos to help make some more sense of it.
Thanks heaps for any help!
Current Patio
Current Patio
Klevaklip Joist base spans
Dimensions
