Change single fence gate to a double gate
rbaus
Hello all,
I am looking for solution to extend the fence gate by removing the middle post and was wondering what would be the optimal way of going about it. Ordering a custom gate seems way to expensive. Any ideas would be greatly appreciated.
Re: Change single fence gate to a double gate
Hi @rbaus,
The easiest solution that I can see is to have a double gate. You already have a post in place, you would just need to cut back the rails, remove the central post and then hang a gate on the post to the left that meets the existing one in the middle, then install hardware.
You would start by cutting out the rails, then removing the fence post. You could cut the rails flush with the post on the left using a reciprocating saw or a handsaw, then unscrew them and the mesh from the post on the right. Assuming the fence post is concreted in, you can then use a fencing bar to dig out and expose the concrete. It will take a bit of work, but once it is free, you can lift it out of the hole. If the concrete is too heavy to lift as one, you can use a rotary hammer drill or a jackhammer to break it up.
Once the post and rails have been removed, you can then construct a second gate using a suitably sized gate frame for the opening. You would then just attach some palings to the gate frame, attach the frame to the post using the hinges that are provided and then attach a drop bolt to one of the gates, and a gate latch to hold them together.
Let me know what you think, and if you have further questions, please don't hesitate to ask.
AlanM52
Hi @rbaus,
Good advice from @JacobZ and with regard to the middle post concrete thing I have some thoughts the should eliminate all of that from the job, no digging, removal, breaking up and... no need for disposal.
Looking at your photo (and I like the way you superimposed the measurements) the middle post is offset to the left by 30mm from the right edge of the post so here's what I am thinking, cut the post at the base just above the concrete and continue on with the job.
Later on when installing the drop bolt things should line up and you can simply drill a hole in the concrete.
If that doesn't work out don't worry come back to discuss some more...
Hi @AlanM52,
That's actually a really good idea that I hadn't considered.
@rbaus, this would be a great way to reduce the amount of work and give yourself something to support the drop bolt once the second gate is installed. Definitely worth considering.
Thanks @AlanM52  and @JacobZ - I think @AlanM52's idea sounds easier to implement :smile:
Now I need to find a suitable gate frame, from what I have measure, I would need a gate 1340mm wide to be able to put a latch on top of the existing gate. Any ideas if Bunnings sell anything I could make use of?
Thanks heap.
Hello @rbaus
I suggest looking at the Fortress Gate Frames. They come at fixed heights, but their widths can be adjusted using the Fortress Gates 1.3m Connecting Rails. They are reversible when it comes to installation and are rated for outdoor use. You can attach both metal and timber onto the frame itself for coverage and is relatively easy to install.
