Hi folks,
I’ve just bought a townhome and want to make it a little more me with a fresh front door. The exiting door is much bigger than a standard door at 2300x930x40. I see Bunnings have door that is almost the right size at 2400 tall (https://www.bunnings.com.au/hume-2400-x-920-x-40mm-external-door-duracote-flush-solidcore-stpc_p1970...), can this be cut down to the right size, and second question, can I get the holes for a particular lock done for me as I don’t own the right equipment?
Hello @blakecrichton
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your door.
The Hume 2400 x 920 x 40mm External Door Duracote Flush Solidcore STPC has a limited cutting profile, and it is not advisable to cut it all the way down to 2300. The good news is that you can custom order the very same door to the size that you need it to be. Simply visit your local store and speak to the special orders team and ask them for a quote for the Hume door to the size that you need. Once you have the quote in your hand all you need to do is to approve its purchase.
In regards to the door knob, I recommend checking out the stores Door Lock Installation Service if you are looking to have a professional install your door knob.
