Options
How much linear meter decking do I need to order for replacing whole deck of 38m2?
December 2021
Most helpful
Re: How much linear meter decking do I need to order for replacing whole deck of 38m2
December 2021
Hello @AdamsDeckReno
Welcome to the Bunnings Workshop community. Thank you so much for joining us and sharing your question about how to calculate the linear meters needed to replace your current decking panels. I suggest the following steps below.
- Calculate your area first. If you have areas that are not part of the main deck, I suggest calculating them separately. For example: If you have a decking area of 7(L) x 5.43(W) = 38m2 (decking area).
- You'll need to divide your decking area by the width of the decking boards. For example: If you are using 90 x 19 it would be represented as 0.090 you then add your gap of 3mm which brings it to 0.093. So 38m2 divided by 0.093 = 408.60 rounded up would be 409 LM.
- Ideally, you would add 10 percent for timber wastage. 409 LM x 1.1 = 449.9 rounded up would be 450 LM.
Please keep us updated with your progress, we look forward to seeing your deck renewed.
December 2021
Thank you. I will remeasure to have the exact dimensions.
You might also like...
Subject | Author | Posted | |
October | |||
June | |||
October 2023 | |||
March 2024 | |||
August 2022 |
