How to attach stringers to weatherboard concrete cladding new extension to attach the stairs do we hv to cut the cladding and put wood there first to attach stringers ??
old temp stairs new stairs in shed
cheers
Beb
Greetings Beb (@beb69),
Welcome! It's fantastic to have you as part of the Bunnings Workshop community.
There's no need to remove the weatherboards, I am almost certain there will be timber behind them.
Assuming the floor is in line with the bottom of the door, there will be a timber bearer running underneath the door frame.
You can always check by predrilling through the weatherboard. You will be able to feel the timber behind the weatherboard.
Hi Jacob
yes there is wood behind cladding
thanks for getting back to us. Uploaded some pix with new stairs from Bunnings to install on house
do we cut the notches off so it’s flush to house .do we put these clamps brackets on the stairs and house two photos with circles drawn do we screw through the top to attach to house
cheers Beb
yes there is wood behind cladding thank you so much
Hello @beb69
I believe the notches will need to be cut off in order for the stringer to be installed properly to the timber bearer. If properly anchored, I don't think it's necessary to install a joist hanger under the stringer. But before you start fixing the stairs to your house, I suggest checking your local council's rules and regulations in regards to attaching steps to your home.
Hi Eric
ok thank you will c what council has to say
cheers
really appreciate your comment
thank you
Beb
