Hello
I realised this has been done to death but I'm in the planning phase of a low level deck. Just hoping to get some simple, sound advice.
The deck will be 8m X 5m and will replace our paved area in the alfresco. The part where I'm scratching my head is deciding to build on top of the existing paving or ripping the oavers up to gain a bit more height. I want to set the deck flush with the zero brick level, the measurement from paver to zero brick is 75mm but if the pavers get pulled the measurement will be 135mm. The tightest measurement that I can think of is using a builders edge pedestal foot at 35mm on a 50mm paver plus a 90 x45mm joist and the ekodeck board will be 23mm thick which in total will be 198mm.
Is it just a simple case of losing sand to make it higher or can the pedestal foot rest on something thinner than a 50mm paver.?.
Kind regards
Ok great, that helps slot.
Do you think noggins would be required in between the joists ?, I see alot of people using them
Also the concrete is very inconsistent, it's quite bumpy in parts and quite skinny in other parts. Most of these pedestal feet have a diameter of around 150mm.
Would it suffice to get a paver and footing on the sand as close to the brickwork as possible or is it critical to have support right at the edge under the bearer
Also......sorry to back track but is it possible to attach 2 or 3 ledge board pieces and position them to avoid the weep holes
Hi @Heath1980,
Yes, noggins are always a good idea. They help stiffen the frame by reducing joist movement, which improves strength and load distribution. They also prevent twisting over time, keeping the deck surface flatter and more stable.
In theory, you could use small sections of ledger board to prevent the weepholes from being blocked and remove the need for pedestals close to the wall, but as I mentioned earlier, you would need to confirm with a suitably licensed professional that the brick structure is capable of supporting the additional load of the deck.
I think it is worthwhile to have a quick look at @maker_m82's discussion How to build low level floating deck and not cover weep holes, which is ongoing and very similar to your project.
In their situation, I recommended removing the bearer from that end and instead running the joist up to the wall. Considering the issue of the concrete on that edge, I think this would be a great solution for you as well, because you can have joists overhang your pedestals by around 300mm without any issues whatsoever.
Do you have the same issue with the concrete foundation on the wall to the left of the door where you'd be running a double joist?
That side could be a little bit trickier to manage, so I'll see what you say before we delve too deep.
Let me know what you think.
Hello
Yes the wall to the left is pretty much the same unfortunately. Just inconsistent concrete that wouldn't be of much use
Hi @Heath1980,
I've really racked my brain and can't come up with a great way to get the support on that side of the deck without utilising the concrete in some way or attaching framing to the brick, which I am trying to avoid.
Is there any way you could dig out beside the concrete foundation, then install a paver at the same height as the concrete so the pedestal could sit across the two surfaces?
You might have to chip away or cut some of the edge of the concrete to get things flush, but it is about the only way I can think of to do it.
Did you have any thoughts or ideas for that side?
If worst comes to worst, attaching some framing to the brick between the weep holes could be an option, but we should try to avoid it if possible.
Hello again........
Thanks again for your input, I haven't really had a chance to inspect the concrete in between work etc. but wanted to ask from a design perspective.
Would you still implement the breaker boards as per diagram even with the brick pylons positioned the way they are?.
Would it look funny ?.
And to implement a fascia board on the outside edges, would it be better to use a 140x45 on the outside rather than a 90 X 45.
Is there any reason why you'll be doing two breaker boards, @Heath1980? Visually, it would look more appealing with the single right in the middle.
Yes, having a 140mm timber on the outside would provide a wider area for affixing your fascia board. However, it can be done with a 90mm too.
Thanks for clarifying that........yes I agree about the single beaker board but I can t figure out how to do it on the ekodeck planner.
I've spoken with Ekodek @Heath1980, and you can certainly go with a single breaker board in the middle. The reason it is giving you two is to do with the best usage of the boards and reducing wastage. If you have a single breaker board in the middle, you'll have a run of 4000mm per board and a waste of 1400mm per 5400mm board you purchase. However, with two breaker boards, you'll have runs of 2480mm, so you'll get two out of each 5400mm length and only 440mm of wastage.
The difference between the two designs is approximately 33m of waste, which represents a significant cost.
