How to caulk balcony tiles?
Joshuam08
We have a tiled balcony and some of the caulking around the edges has started to split. What type of caulk should be used on a balcony? The one that is currently there appears to be the same one used in our bathroom, but I wasn't sure what what should be used for indoors vs outdoors. Preferably if we can get something slate grey that would be great! I believe I will need to remove the existing material, clean it and then apply a new bead?
Re: Caulking Balcony Tiles
Hello @Joshuam08
You are correct, the old caulking will need to be removed in order to put in a new sealer. I suggest using a Trojan Safety Scraper With 5 Blades to remove the old caulking in combination with DIGGERS 1L Methylated Spirits to clean the surface. I suggest using Sika 310ml Grey Concrete Sikaflex Pro+ Polyurethane Sealant to seal the gap.
Here is a handy guide that will help: How To Silicone Seal A Bath (the techniques used are applicable to your project)
Joshuam08
Forgot to check on this for an update! Would Selly's Roof and Gutter Silicone also be suitable for the job?
Hi @Joshuam08,
Selleys 310g Translucent Roof And Gutter Silicone Sealant is ideal for repairing leaks in most forms of roofing and guttering. For tiles, it's best to use a product that is designed more for that purpose. Sika 310ml Grey Concrete Sikaflex Pro+ Polyurethane Sealant is specifically designed for gaps around tiles, and I feel it would be the best choice for your project.
Joshuam08
Thanks for the reply! Happy to use that, I just wanted to check as it almost looks like the same silicon that was used in my bathroom was used outside and I thought it looked more like silicone than poly. Here’s a pic of the area but happy to use that if it’s the best option!
