How to install outdoor decking on grass?
skpanchadar
Can someone advise how to install a outdoor decking on the turf. The srea is not big so prefer to do it myself. 1.5m x 3m only. Is there something like clip on like timber flooring.
Neo19
Making a Splash
Re: outdoor decking on grass
This would be somewhere helpful to start...
https://www.workshop.bunnings.com.au/t5/How-To/How-to-a-build-a-deck/ba-p/102739
More details about your projects including finished height, photos of the area etc., will get you more specific advises from this helpful community.
Hello @skpanchadar
Welcome to the Bunnings Workshop community. It's fantastic to have you join us, and thank you for sharing your question about building decking on grass.
It's great that you've received excellent advice from @Neo19. I also suggest having a look at this guide as well - How to build a low-level deck by @Adam_W. It will give you the basic information you'll need to consider when you plan your decking frame. If you're building a low-level deck, I suggest using TuffBlock 300 x 300 x 90mm Instant Foundation System Deck Support or the adjustable type Builders Edge Pedestal Feet. You'll need to use pavers underneath so that the pedestal feet have a good base to stand on.
Would it be possible for you to post a photo of the proposed location for the deck? In this way, our members can assess the area. We can then offer recommendations on a possible layout for the deck.
Here is a link for ideas and inspiration: Inspiring low-level deck builds.
Here is a good example of pedestal feet being used on a deck - Low-profile deck with screening and steps by @MGusto
