How to lay artificial grass
Hi Bunnings Workshop community,
I'm hoping to lay artificial grass within the blue section, but have never done this before.
Do I need to add a membrane underneath first? Which artificial grass would you recommend for a courtyard like this?
What tools would I need to cut to the shape as shown in blue?
Will there be an issue in simply cutting a hole out of the grass where the drain is (red circle)?
Finally, are there perhaps other routes anyone would recommend I go down other than artificial grass? My hope is to make it a more friendly area for my little kiddos, so they'd be happy to walk outside and sit/play there - the concrete/slate there currently gets dirty easily and is not exactly inviting. Will also be getting outdoor furniture at a later point.
Thank you!
Re: Artificial grass help
Hi @Gekman,
Laying artificial grass in your courtyard is a fantastic idea to create a kid-friendly and inviting space. However, you need to note that artificial grass isn’t designed to cover hard surfaces like stamped concrete or pavers. As you can't use ground pins, you might need to consider glueing it down if it moves around too much.
When selecting artificial grass, choose a high-quality option that mimics the look and feel of natural grass. Tuff Turf 3.75 x 1m Luxury Synthetic Turf is a great choice as it is durable and designed for high-traffic areas.
When it comes to cutting the grass to fit your space, a sharp utility knife or carpet cutter will be essential. Use a straightedge or ruler to guide your cuts for a precise fit, especially around features like drains. Cutting a hole for the drain is feasible; measure carefully and make the hole slightly larger than the drain to ensure proper drainage.
If you’re exploring alternatives to artificial grass, consider rubber pavers. These can also create a welcoming and durable outdoor area for your kids.
Thank you Mitchell, you're an absolute legend!
Are there any slightly cheaper versions of the artificial grass you might recommend? Noting it won't be too high a traffic area.
Also, is there a specific glue you would recommend noting as you mentioned we can't use pins?
Thank you!
There are several more budget-friendly versions @Gekman. Here's our whole range. Something like DIY Turf 1.8m x 20mm Pile Lifestyle Synthetic Turf would be more than adequate, or you could still go cheaper.
I'd recommend Tuff Turf 320g Synthetic Grass Adhesive for adhering grass to hard surfaces. However, this adhesive would be difficult to remove later if needed.
Amazing, thank you Mitchell! Have a great day.
Subject | Author | Posted | |
December 2022 | |||
April 2024 | |||
October | |||
July 2024 | |||
July 2021 |
