I have an old concrete slab for my outdoor patio that I want to renovate. The slab is level but cracked in a few places. I was thinking of Travertine but then thought maybe this would look ok https://www.bunnings.com.au/brighton-masonry-300-x-300-x-40mm-sand-mypave-paver_p3451558 with the advantage of easily fixable if I mess up because I can just pop in to Bunnings for more. My questions are:
Do you think it will look ok? I had in mind this colour scheme https://www.berger.com.au/inspiration/a-modern-patio-that-shines/?fbclid=IwAR1hfZrxWpG-xLVdlLMh8DO0J... (my patio is very old fashioned with round columns everywhere)
What would I use to lay the pavers?
What would I use as edging
Angle grinders are quite intimidating machines, @lakiita. Being weary is important, as most accidents occur when caution is not observed. Remember to have two hands gripping the machine at all times when cutting and wear appropriate PPE, including eye protection, face mask, gloves, and tightly fitting clothing. Also, if you have long hair, it's important to tie it back. Take your time, don't rush the job and let the tool do the cutting work; don't force it.
thanks
yes to all the above
am having trouble figuring out how to see my cut line with the dust (don't worry I have safety glasses and mask)
can I wet the paver????
first line ended up wonky
You can wet the paver @lakiita; just obviously keep running water away from the machine. I'd recommend you start by doing a shallow 5mm deep cut following your marked line. Then, do progressively deeper cuts until you are through the paver. You won't be able to do a full-blade depth cut and keep it straight.
@MitchellMc I am REALLY bad at this - attempt no 2 also wonky
If my third go doesn't work I will have to stop I think as I don't want to waste too many pavers learning
Don't be disheartened, @lakiita. Perhaps use one paver to try your practice cuts on. It's taken me many years of odd jobs to be able to cut straight lines with an angle grinder. I wouldn't consider it a beginner-friendly tool as there is nothing to govern cutting straight lines; it's all free-hand. I believe I mentioned it earlier in the discussion, but a table-mounted brick saw is exponentially easier to use. You place the paver on the sliding bed and push it through the blade. This keeps the cut perfectly straight.
I don't think I would be able to fit this in my suzuki swift
hence the angle grinder
attempt 4 is kind of ok - am using off cuts atm and I do have quite a few pavers to play with
it's def NOT a nice tool to use
the above was my 'successful' cut. Not sure if it's ok or not so change in plans - have called the hire shop and they say the brick saw will fit in my car so I'm going to hire it for 24 hours - should be able to get all my cuts done in that time and it will be much safer.
Dammit was just watching the 'how to use' video and it says you need 2 ppl to lift it so I'm back to the angle grinder
Wish me luck
I mastered it!!! I went to Bunnings and bought myself a smaller angle grinder. It means cutting from both sides but it's sooooo much more doable AND because it's smaller it doesn't throw as much dust so I can see my line better as I cut. It's a slower way to do it but the result is excellent. So proud of myself for not giving up and finding a work around. I feel like such a hero every time I finish a row 😁
