Hi Workshop Community,
I am attempting to build my biggest deck to date, and wish to seek some advice on how to optimise my framing (and therefore, effort) for the deck. Deck will be low height (approx 500mm above the ground). Refer to the frame layout below
Purple - 90x90 H4 Treated Pine Posts -> fixed into full stirrups embedded into concrete foundations
Orange - Bearers, 140 x 45m H3 Treated Pine, fixed to the posts with 2 M10 bolts per post
Green - 90 x 45 H3 Treated Pine Joists, 450mm centres, sitting on top of the bearers and attached using metal joist straps
Finished Surface - 89x19mm blackbutt to match already completed decks
I have access to the AS Span tables and have used them to set out my frame to date, but not sure if my plan is overkill. Looking for any possible optimisation, as mentioned earlier
Also looking for some advice regarding joining bearers together. Obviously I aim to keep the bearers as long as possible, but a joint is unavoidable. My current thought is a butt-joint and a plate joining the members? Something like this https://www.bunnings.com.au/dunnings-200-x-35mm-m10-galvanised-bracket-plate_p1076799?srsltid=AfmBOoqiLhZ3V1nJjX_m7qlGXImoZ-t61Ug2KLahX6j_eC-2E0QoAINE
There is a set of stairs to build in the middle, but I'm leaving that for another day/post 😋
Seeing some other posts, I have already checked council standards and don't need any permits etc. to do this, given the low height.
Thanks in advance
Bob
