Hello helper’s,I am wanting to patch hole in spandek roof after removing fireplace in outside room,patch needs to be watertight but not perfect,hoping to use tape under and over or paint on membrane as hole is too close to roof joins to add a piece,what would be recommended and what product suitable,Hole is a lot smaller than outer cover,Cheers GlennC.
I'd suggest using Sikaflex 11FC to stick the lead flashing down @GlennC. Ensure there is a full perimeter around it. Then, once stuck down, go around the edge of the sheets with more so it creates an exterior gasket between the lead and the roof sheet. I'd probably then go over that with butyl-backed flashing.
I've created the rendering below to help illustrate.
Afternoon @GlennC
Woooooo I was well and trully up the chimeny without a ladder
Sorry about that, not sure how I missed it 😕
Id go with @MitchellMc suggestion for sure ![]()
Good on you Dave,you’re input has been stored and appreciated,Glenn.
Thanks Mitchell,much appreciated this is how it will be done,all materials in my cart for Bunnings day out,Cheers Glenn.
