How to sand back outdoor furniture before oiling?
lauravdh
Hi, I got a wooden IKEA outdoor furniture set from marketplace on the weekend and thought I’d freshen it up by giving it a kick of furniture oil.
I roughly sanded it and started to apply the oil but it turns out the oil is
quite transparent so showing the rough sanding job below.
for sanding preparation, should I be sanding every cm of the furniture before oiling? Thanks!
Re: sanding back outdoor furniture before oiling
Hello @lauravdh
Thanks for sharing your question about your outdoor furniture. I suggest using a detail sander to get to those hard-to-reach areas of the furniture. A good example would be the Ozito 200W Detail Sander it comes with a complete sandpaper package that should be enough to give your appliances a full sand down.
Whatever was used formerly on the furniture, it must be sanded off completely in order for you not to see it when you apply the furniture oil. Failure to do so means that the oil will not properly penetrate the timber and you'll end up with a patchy finish.
Here are some excellent examples of upcycled furniture our Workshop members have shared:
lauravdh
Thanks eric,
I have an ozito sander so will continue to do some sanding work on the pieces. Is it ok to go over the section I have already oiled? (The half bench as in the picture)
Hi @lauravdh
Yes, it's perfectly fine to go over the oiled section, just keep in mind that it might clog the sandpaper a bit.  I therefore suggest tapping and cleaning the sandpaper more often than usual.
