Laying deck on concrete slab
TK87
Hi all. I'm looking to lay decking over an existing concrete slab. The slab has existing water proofing membrane and is 4.8x5.7m.
I'm keen to use a composite panel product (e.g. Ekodeck).
Are there pedestal products that I can use that substitutes the need to build a joist frame structure?
Would love to hear from advice.
Cheers!
Adam_W
Workshop Legend
Re: Laying deck on concrete slab
Hi @TK87 & welcome.
Would the Good Times system work for you? I'm thinking the supports rather than the entire system due to your size.
With any deck you'll still need a bearer & joist structure of some sort. @EricL mentioned the Steel Deck system & I have used that and found it great. Quite cost effective and larger spans than timber are achievable due to the strength of the steel. It also uses a joist inside bearer box-frame structure so only one 'layer' in height as opposed to the typical layer of bearers, layer of joists.
MikeTNZ
Hi TK87,
I'd be interested to see how this turns out.
Mike T.
Hi @TK87
It's great that you got fantastic advice from @tom_builds and @Adam_W. Looking at the photo you posted in your last post, are you installing this on an existing elevated structure? Just a friendly reminder at having a look at your local council's regulations regarding building a deck over existing structures. We want to make sure your build is safe and passes the local council's rules.
Please keep us updated.
TK87
Thanks Eric. And yes, have council approved plans (and a DA) so all good to go. And rest assured a fence is going in!
Will share some progress shots as I go 👍
