Hi
I received a Bosch Universal Aquatek 130 pressure washer as a Xmas gift. I would like to ask for a few recommendation for a heavy duty 15-20m extension cord for this pressure washer; preferable with some safety features.
Hi @Ericlim,
With your extension lead being used with a pressure washer, the main thing you'll need to consider is water, so protecting the connection between the plugs is the most important thing.
I'd suggest this Arlec 15m Heavy Duty Extension Lead With Bonus IP44 Cord Safety Box, or a similar heavy duty extension lead with an Arlec IP44 Outdoor Safety Box.
Hi Jacob
Merry Christmas! Thanks for your prompt response.
Does this comes with auto switch off for overheat / overload so that it would not affect the fuses at the home electric switchboard?
Is it better to get those with reel for easier storage?
Hi @Ericlim,
Merry Christmas to you, too.
No, they do not come with built-in overload protections, although I wouldn't say they are 100% necessary, as electrical circuits are protected by circuit breakers at the switchboard.
If you were concerned and didn't want to rely on the circuit breaker in your switchboard, then you could always use a Click 25m Heavy Duty 4 Outlet Cable Reel which has these inbuilt protections, but I would still recommend using an IP44 cord box to protect the connection between the pressure washer and extension lead from water.
