Hi there,
I am going to make a box with this product. What Gauge and length outdoor screw do you recommend and let me know if Galvanized screws are more resistant to rust or stainless steel screws?
Thank you in advance!
Hi @Marten
I was leaving this for others to help you but 4 hours later here I am. To answer your question Stainless screws are resistant to rusting depending on there grade of stainless. I would use stainless if I was making something on a boat or a pretty box. Where as galvanised screws are mild steel like screws with a galvanic coating which is also very good even if coating chipped. This would be the better workhorse choice if you like them rust free.
But the truth is normal screws are also pretty good and not prone too readily rust (unknown alloys)even if they go rust on there heads they are still working in case you have a bigger project using many screws as stainless are rarely in stock by the box.
I recommend a big box of screws as you sound like your getting handy and spare screws always a boon to have at hand. These are 40mm so 20mm through your wood and 20mm screwing into wood a good solid screw length for many purposes.
Over time get big 500 to 1000 qty screw boxes different sizes 20mm to 100mm screws Its nice to have them ready to go either galvanised or regular.
8 guage to 10 guage is thin but strong as thicker screws can splinter wood unless you pre drill first. If you splintering wood and can t predrill try rubbing screw point or nails on your scalp as the oils on your head will help lube the screw and nail an old carpenters trick still valid today. (unless the future arrives today and the builder is an andriod. Furphy)
Today
Zenith 8 - 10 x 40mm Galvanised Countersunk Rib Head Timber Screws - 500 Pack I/N: 2420874 $30.89
Hi @Marten
It's great that @Jewelleryrescue has given you excellent advice. Another way to prevent your timber from splitting is to pre-drill holes in the timber, otherwise known as pilot holes. I also recommend counter-sinking your pilot holes so that you get a nice flush finish. I propose using P&N 4 Piece Quickbit Pilot Drill / Countersink Bit Set. The Zenith 8 - 10 x 40mm Galvanised Countersunk Rib Head Timber Screws should work nicely and provide you with a long service life.
It sounds like an interesting project. What kind of box are you building and what will you use it for? Any updates you can provide would be very much appreciated.
Hi @EricL
Thanks, It's a wheeled big box which I will make it to use it as dust bath for chickens. That's why I got a premium marine grade poly wood and I will reinforce it with 35 x 70mm pine. I will seal it with Marin Spar Varnish of Feast Watson at the end. Wheels are heavy duty locking casters.
Just a quick question, in general, any timber which I will varnish, do I need to oil the timber before varnishing? I mean applying oil to the timber before varnishing, gives me extra wood protection?
Hi @Marten
I never heard of a dust bath for chickens before, I can see it working though. Can I ask you a question what dust do we provide them? Clean saw dust maybe I am just guessing. Thank you for sharing your knowledge too thats what Bunnings workshop is for.
With timber you can oil it or seal it with other varnishes etc but not both at the same time Oil soaked into wood will repel varnish not letting it bond with wood. Varnish type products will soak and dry in the wood and repel oil and every thing else.
Only far to answer your questions now. With timber you can oil it but this wont be a good idea with dust as the oil will want to mix with dust and not look good . Oiled timber requires yearly oiling to keep it looking sharp so is pretty much not a favour it choice these days and maybe less clean for your girls.
So your choice of Feast Watson will work under cover out of the weather as a better choice and not need maintenance. Another option is
Sikkens Cetol Deck 1L Natural Timber Finish I/N: 1580495 $57.20 As it UV stable and weather/ cleaning resistant. As a deck oil more resistant to chicken scratching while loving there box As its advanced formula it is oil based but sets like a hard coating so an unique product. Chicken purists will want stuff like beeswax and ultra natural stuff in there linseed oils etc and I say yes great it you want that extra work. I used modern paints in bee hives and they where 100% ok as a bee keeper. Bees are super sensitive to chemicals.
I would do like 3 coats to try seal the box against mites that chickens can attract to there coop. Your chicken knowledge is most likely far greater than mine as I was a hobbyist only. So my chicken where infected with mites and the coop needs to be cleaned an steralized to fix the problem and the girls needed a chemical bath and us too because we where cleaning out their environment.
So in short any thing we make for the girls needs to be easy to clean from top to bottom with regular coop muck outs. Chickens dont really eat wood so using this as a finish in their dust box should be fine.
Ps I like you solid build ethics @Marten ie the heavy materials and they are easier to assemble.
Hi @Marten
Ps I like you solid build ethics ie the heavy materials and they are easier to assemble.
Thanks, it is big pleasure if you acknowledge mu build ethics. My perfectionist personality believes in premium quality materials ![]()
My recommended mixture for chicken dust bath is combination of fine sand, dry dirt, diatomaceous earth, wood ash, used coffee ground and fragrant herbs concentrate.
Also mixture of diatomaceous earth and fragrant herbs concentrate, spread around the coop keeps ticks, mites and lice away from the girls.
My chickens in their temporary enclosure
Hi @Marten
Nice to meet your Ladies. (Isa Browns) or Rhode island red with nicer plummage?
I have no idea on the chicks, your little brown one is unusual coloring , But they all look very nice. I can almost hear them softly clucking and your ethics and personality also extend to looking after them with a fine mix for there dust bath. I wish I knew more about diatomaceous earth back then. I am not even sure it was avaliable as I try treat my companions the best.
Silky's and Rhode reds out of photo
While broody I hand feed golden hen canned corn. 28 years ago, still fond of them.
Hi @Marten
Using Feast Watson 1L Spar Marine Varnish should work very well for the dust bath you are planning to build for your chickens. If you are leaving it outside please make sure to keep it out of the rain or perhaps build a roof structure over it. Please make sure to post an update, I'm sure our members would be keen to see what the finished dust bath looks like.
