Hi, I am at the stage of screwing the Merbau 140mm decking boards to the frame.
i am planning to go with either this
or this
question, which one is better for my boards (Truss or Trim)
does this screws also do countersink or I need to do a seperate countersinks
and final question
will 50mm screws be enough or should I go with 65mm
Thanks in advance
Hi @coolnav,
There will not be much difference in terms of performance, the main difference is aesthetic. It's entirely up to you, but I think the trim head screws usually look better as they are less perceptible.
Either of these Bremick screws do not require countersinking, but it is usually best with any decking to predrill.
I generally recommend using 50mm screws when installing boards that are 19mm or thinner and 65mm screws when installing thicker boards then 19mm.
Thanks @JacobZ , If there is no performance difference between Truss and Trim , I like the aesthetics of the Trim, I will go with the Trim and will post some pics here after my install if that helps others ![]()
