How to fix big gap under weatherboard house?
hannahk
Community Newcomer
We have just bought a 1920 weatherboard Californian bungalow. We have heard and seen rats coming out from underneath the house and there is a large gap between the bottom of the weatherboard and the ground. What’s the best approach to blocking this off whilst still allowing airflow to the subfloor?
thanks Hannah
AlanM52
Amassing an Audience
Re: How to fix big gap under weatherboard house?
Hi @hannahk,
I have been doing backyard chooks for like 25 years and also helping others (even in rural areas) so the first thing I suggest (which may sound silly) is collect some background info about your enemy - they are smart. For example (if in your area) the Brown Rat is a very capable digger so you will need an even deeper trench for the heavy duty wire mesh barrier around the house. There are also other variables, you may find the rats you evict from under the house end up in the roof. If you also have the Northern Hopping Mouse in your area (that may turn up) you will need a 1/4" mesh.
I generally propose the following, dig a narrow trench around the house in preparation for the already purchased wire mesh barrier and stop at that point. The next step is to entice the rats out and then install the mesh barrier secured to the bottom board.
All of the above may sound convoluted but it's very likely they will cause damage... even gnawed electrical cables.
Cheers
Hello @hannahk
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about the gap under your weatherboard house.
It's great that you've received excellent advice from @AlanM52. I totally agree with his strategy of luring the rats out first before fixing the mesh permanently. I would also like to suggest fitting a sleeper horizontally (lying flat) at the bottom to serve as an anchor point for the mesh.
