How to automate light and alarm alert using Arlec Grid Connect?
I am trying to automate when the Light & Alarm Alert System with night lights bedside assist alarm is triggered to set off the Smart Outdoor Siren...
I can get the automate to work if I turn a smart light on the outdoor siren will activate, but not if the bedside assist alarm is triggered. Also, if I try to get the bedside assist to turn a light on when it is triggered it fails. It appears that the bedside assist will only send notifications and cannot be used in any automation...
I would like a much louder alarm in case my partner needs assistance.
Re: Arlec Grid Connect Smart Bedside Assist Light Kit
Welcome to the Bunnings Workshop community @mlcollingw. It's a pleasure to have you join us, and many thanks for your question about Grid-Connect triggers.
Let me mention our resident Grid-Connect expert @CSParnell to see if he has any thoughts. You can also speak directly to Arlec and their Grid-Connect technical team, who are familiar with the system's capabilities, on Ph: 1300 267 168. Sometimes it's easiest to talk through the scenario with a technical assistant and make adjustments to the app as you go.
You might find these Grid-Connect user guides useful as they cover quite a few of the technical aspects of the system.
Hey @mlcollingw and @MitchellMc
You will need to have the automation in the following sequence.
When all conditions are met
If:
Night Alarm - Triggered
Study Lamp - on
Then:
Outdoor Siren - alarm light on only
If you want it on a timer then add a countdown for anytime after the outdoor siren -on
So
Outdoor Siren ---- on
Countdown 2min
Outdoor Siren --- off
Study light ----- off
Night alarm ----- off
Otherwise if you have another setup in mind let me know and I'll help you through automation code.
Re: Arlec Grid Connect Smart Bedside Assist Light Kit questions
Just looking at your question again I have not looked at those alarm devices but if the alarm alarm indoors is an all in one device can you add the device twice in the
IF command once for light once fir alarm and change the when any device to when all devices ?
I can do this for many of the other devices.
Thanks @CSParnell
The study light was only added for a test to see if it turned on would the outdoor siren activate (lights only as it is rather loud).
The Arlec Grid Connect Smart Bedside Assist Light Kit has two master states to choose from:
- Normal; or
- Alarm
It does not have a 'triggered' state
Ok I'm with you now the kit you have it this.
Which it looks like the PIR on the light us not an active smart trigger which is ashamed.
You can add a smart sensore on like the following 2 or a Tuya brand WIFI
That will give you the PIR sensor you desire onto the Grid Connect Platform.
Again thanks! What I need is if the 'panic' button is pressed to activate the outside siren. I do not need the PIR to trigger an alarm
The 'alarm' on the Arlec Grid Connect Smart Bedside Assist Light Kit is not very loud
Very disappointed as it said on the box and website that it can be used in automations
Looks like I may have to get the security system that features the keypad etc and use the panic buttons on that.
Hello @mlcollingw
I'm sorry to hear that the Arlec Grid Connect Smart Bedside Assist Light Kit is not loud enough for you. I suggest augmenting the alarm sound with an Orion Grid Connect Smart Indoor Siren and Chime.
There is also a keypad system such as the Orion Grid Connect Smart Alarm System with Keypad. Both units can be linked to the Grid connect system.
You can always browse Aliexpress for Tuya wifi or zigbee products as they fit right into the Grid Connect environment.
