Whenever we receive a substantial downpour the roof leaks into a bedroom, almost like a tap is running. I myself cannot see where on the roof that it might be coming in from so that I can repair it. There is no ceiling access to see from under the roofline.
I think it is somewhere near the two different rooflines *See pics. Bedroom is under the lower roofline where the newer sheeting is.
Hi @CMaco,
Finding the source of a roof leak can be quite difficult. Even more so if there’s no access to the space under the roof to see where the water is getting through. Water doesn’t always appear directly below the entry point; it can travel along roof framing, battens, or insulation before dripping down somewhere else. This can make it challenging to locate the exact source.
When the roof is dry and safe to inspect, start by checking carefully for cracks, gaps, or lifting in the roof sheeting, flashing, and sealant. Look for any loose screws, rusted areas, or places where different materials meet, as these are common entry points for water. If it’s safe to do so, you can also run a controlled water test. Have another person inside while you use a garden hose or buckets of water to wet small sections of the roof one at a time. Start low and move upward slowly, waiting a few minutes between each section to see if any water appears inside. This method can help narrow down the problem area.
If there is also damage to the ceiling in the bedroom that needs to be fixed, it is likely worth removing the ceiling sheet so you can see inside the ceiling cavity. If there is already damage to the ceiling, then it would need to be replaced anyway, so it wouldn't be creating an issue that wasn't already there.
If you’re unable to find the source, it would be best to contact a licensed roofing professional. They can safely access the roof and use tools like moisture meters or thermal imaging cameras to detect leaks that aren’t visible from the outside. If you notice any areas that look suspicious during your own inspection, mark them clearly so you can point them out to the professional when they attend. This can save time and help focus the repair work on likely problem spots.
As there could be further damage to the roof, it is likely best to have it inspected by a professional, regardless of whether you can find and patch the leak or not. It's all well and good to fix the source of the leak if you can locate it, but ignoring the unseen damage that it might have caused is not advisable.
I had similar issues, so hard to find roof leaks on metal roofs as the water will track along battens, over rafters and under sheeting, I started by replacing all of the roof screws, get decent ones with good gaskets, cleaning and treating each screw hole, I also used a bit of coloured roof silicone, also I didn't think that the ends of the roof sheets were turned up under the cappings and for various reasons I wasn't able to lift the cappings to take a look, so I injected expanding foam under, using frog tape or similar to get a clean line after trimming. Starting at the top first working down slope to ensure no voids at higher levels to trap water.
There were a few pin holes and missing screws from fittings that had been removed, I sealed these up with Crommelin High UV roof water proofing. (Look up the product to get right one)
I have had a few minor storms since and I think I have sealed the leaks, but waiting for a decent downpour with wind to be sure.
My roof has a colorbond finish so I have patch painted with spray cans and will ultimately spray the whole section of roof after I have finished cleaning it.
Hi @SKETCH3D,
Welcome to the Bunnings Workshop community, it is wonderful to have you with us and thank you for sharing your experiences with your own roof and advice around what you did.
If you are finding your problems persist, we may be able to assist, so don't hesitate to reach out.
Also, allow me to tag @CMaco so they are notified of your comment.
Hi @CMaco,
I suspect the older top section (circled) has a water problem.
Rather the looking for the leak(s) isolate the area.
Lay down a tarp and make sure the top edge is past that row of roofing screws.
Have someone in the bedroom on the phone and 'water' the area.
Let us know how that works out...
