How to install a ceiling fan?
quasilvia
I am trying to install a ceiling fan in a 1965 apartment. The apartment has pop corn ceiling and there is already a box there. Unfortunately I have no idea if it will hold the fan but it looks pretty sturdy and the previous light was heavy. Would you suggest to proceed with the installation or replace it?
Re: Ceiling Fan box
Hi @quasilvia,
Unfortunately, this sort of installation is considered electrical work requiring an electrical licence.
For this reason, unless you are a licenced electrician, I'd suggest you cease work and contact an electrician for assistance.
If you need to find an electrician in your area, I'd suggest using a service such as HiPages or True Local.
The electrician will be able to install the fan in a safe and satisfactory fashion.
Re: Ceiling Fan box
Hi, thanks for your reply. But you have not responded to the question. Would this box be suitable for a ceiling fan? Thank you
Re: Ceiling Fan box
Hi @quasilvia,
You'll need to get into the ceiling cavity to check how the electrical box is mounted.
Typically, ceiling fans will be mounted to an electrical box that is attached to either the ceiling battens or the roof trusses with a cross strut. As they create dynamic loads, it is not suitable for them to simply mount on to an electrical box that simply sits on the plasterboard.
If the box is connected in this fashion, you would then need to confirm with the ceiling fan's installation requirements and the electrician whether it is feasible or not.
R4addZ
Becoming a Leader
Re: Ceiling Fan box
Hi
Looking at the type of box in the ceiling, it looks like the ceiling may be solid concrete as that type of fitting is usually on the end of a conduit through which the wiring is run. If this is the case, I would expect it to be able to take the load, but it would be best to get an expert on site for a true assessment.
Re: Ceiling Fan box
Thank you very much! I think the same, however I’ve asked an electrician to come and have a look!
cheers
