How to install timber floorboards over concrete slab?
Lee777
Cultivating a Following
Guys,
Im looking at installing 13mm solid jarrah floor boards on existing concrete slab.
Do you have any videos/publications on:-
Preparation
Any moisture membrane requirements
The best glue/adhesive to use
Installation processes
Sanding, staining and sealing.
Thanks!
Re: How to install timber floorboards over concrete slab?
Hello @Lee777
I've sent the warranty details and a picture of the Medina floor packaging to your email.
Lee777
Hi Eric,
I picked up a sample
https://www.bunnings.com.au/floor-select-6mm-2-2m-blackbutt-hybrid-waterproof-flooring_p0135656
is there an underlay I can install underneath this flooring to get the level to match existing tiles @ 13mm?
Hello @Lee777
I propose having a look at the BGC Fibre Cement 2440 x 1200 x 7.5mm 2.93sqm Duratex Blueboard and placing it on your floor. Keep in mind that it is ever so slightly higher by .5mm so you'll end up with 13.5mm. There is a lower sheet option at 6mm, but that will make your flooring lower by 1mm. I'll leave the decision up to you.
