The box gutter has detached itself from the rendered wall. I tried a similar screw which was a little larger than the original but it didn't hold. It seems impossible to find the stud behind the render so I'll need to drill into render and blueboard(?). Are there special screws that will work in this instance, is there another way to attach this gutter?
You could use Builder's Bog if you need to drill into those sections again @tigerzen. The only way to know if a Ramset 3/16" x 100mm Round Head Spring Toggles will be long enough is to try it or measure the thickness of the cladding somehow.
