We have timber beams running underneath our deck, and the exposed ends of some beams have developed wood rot. We’ve had a few carpenters take a look, and they advised that the affected sections aren’t structurally critical, so the options would be to cut the ends back or paint and preserve them.
Unfortunately, cutting them back isn’t an option, as several of the beams have exterior light fittings attached. We’re therefore planning to paint them.
Before doing so, I wanted to ask whether there’s a suitable wood epoxy or similar product that could be applied first to harden and stabilise the timber ends prior to painting.
Hi @NicoleDIY,
I know it’s not the answer you’re hoping for, but given how far the decay has progressed, the best long-term solution really is to cut those timber ends back flush with the bearer and look at an alternative way to mount or overhang your exterior lights.
The reason for this is that the rot isn’t just superficial. From what you’ve shown, the decay has travelled right up to the edge of the bearer. Even if a carpenter has said those particular ends aren’t currently structural, rot that close to a critical junction is a real concern. If moisture continues to track back along the timber, it can get into areas you can’t see or reach, and at that point you’re no longer dealing with a cosmetic issue but the potential early stages of a deck replacement.
There are timber wood hardeners, and they do have a place, but they’re only effective when all decayed timber is removed first. In this situation, unless every soft or compromised fibre is cut away, applying a stabiliser and paint will only seal over the problem. Water can still migrate behind the coating, under the bearer, and continue rotting the timber from the inside out. Paint and preservatives simply can’t stop that once decay has reached this point.
If trimming them back absolutely cannot be avoided, the bare minimum would be to remove all visibly decayed timber, flood the exposed timber with a quality wood stabiliser, then paint thoroughly. Even then, there’s no guarantee this will be a long-term fix, only a way to slow things down.
From a safety and longevity perspective, though, removing those ends now and rethinking the light fixings is the option most likely to protect the rest of the deck. It’s a tougher decision upfront, but it greatly reduces the risk of the rot creeping further into the structure, where repairs become far more invasive and expensive later on.
