How to sand and seal doors and windows?
Innov8tive
Building a Reputation
For this project I'm needing to buy the right sander for the job - one that gets into small corners and tight grooves as much as is possible with a sander. I'm just wondering what you recommend the best sander to be. I do prefer sanders that have a catcher.
I'm also wondering what would be best to get for a nice sealing of the doors a d windows after sanding.
Re: Sanding and sealing doors and windows
Hi @Innov8tive,
A detail sander would be the best choice for this type of project. They’re designed specifically for getting into small corners, grooves, and other tight spots that larger sanders can’t reach. While there are bigger sanders available, they tend to struggle in those areas, so the detail sander really is the most practical option. You’ll also find most models include a dust catcher, which helps keep your workspace cleaner.
That said, you’ll probably still need to do a bit of hand sanding right up against the glass or in very tight corners. Be careful when working near glass, as it can shatter easily. Always wear safety glasses, cut-resistant gloves, a long-sleeved shirt, long trousers, and enclosed footwear.
Once you’ve finished sanding, you can seal the timber with either an exterior timber oil, which gives a more natural finish and nourishes the wood, or an exterior varnish, which offers a glossy, more durable protective coating. The choice really depends on the look you’re going for.
@MitchellMc
I think I'm keen with the sander I need to actually get - my only concern is if you look at the pic of the door you can see at the bottom of it where previous tenants dogs chewed through it basically. I'm wondering if the detail sander will be ok for that or if a belt sander would be more appropriate for that part. If the 200 watt digital sander would be appropriate I would buy that then.
Also for oil and varnish - I think varnish is a bit annoying to work with personally so I'm thinking to go with the oil instead.
Hi @Innov8tive,
The Ozito 200W Detail Sander would certainly be a good option as it can get into those corners well, but a detail sander isn't the best for heavy-duty sanding over wide areas. It can still do it, it would just take a lot longer than something more heavy-duty, like a belt sander. A belt sander, on the other hand, would be quicker for the rough stuff, but it couldn't be used in the corners, so it is not the best choice for the whole job. Maybe start with the detail sander and see how you go with the slightly rougher area. If it is taking forever, consider getting a belt sander as well.
Oil would be fine, just make sure it specifically states that it is an exterior oil.
Innov8tive
@JacobZ
Thanks alot for that. I will purchase that detail sander and get a belt sander if it's just not cutting it. I will also make sure it's an exterior oil. Thanks again
@MitchellMc @JacobZ
What are the best packs of grit to get for the ozito 200 watt sander me toned and is it best to use a roller or rag to apply the oil.to.the doors after sanding?
Hi @Innov8tive,
The sander comes with 18 sanding pads, 6 of each 60 grit, 80 grit and 120 grit.
You should certainly get by with this many pads on this job. Use the 60-grit for the initial hard sanding to remove the top layer, then switch up to the 120-grit for finishing.
If you need any replacements, you can grab this Ozito Detail Sander Assorted Grits Sanding Sheets - 10 Pack or packs of the individual grits.
Either a roller or rag will work, it just depends on what you're more comfortable with. Personally, I like using a paint brush because I feel I have a bit more control with it, but anything will work really. Just make sure to apply the oil in thin coats so it absorbs evenly and doesn't form a film on the surface.
Innov8tive
@JacobZ
Thanks for the further advice. I'll try a rag and paintbrush to see whatever works best for me. I'm looking forward to restoring these doors and windows.
Innov8tive
@JacobZ @MitchellMc
I ended up going with a different sander to the one I was originally going to purchase. I also think 60 grit is too rough to start with so I'm going to use an 80 grit - sand it back but not use the 120 girt for the finish. Clean it up  and then coat it with the oil based timber protect. I feel happy enough with that as I think it will be a good enough job to restore the doors and windows.
It's entirely up to you @Innov8tive, but going up to 120 grits will help you get a more even and finer finish.
Ultimately, if you are happy with how it feels, trust your instincts. I am sure it will turn out just fine.
